BJT and MOSFET transistors based on active antenna circuit’s two pieces instead of the normal antenna amplifier circuit and PCB antenna through the first circuit made of high quality at a radio antenna, and 2N3866 MOSFET transistors have 2sj310. In 17.2khz active antenna circuit 2N3866 transistor used in crystalline and 4MHz. Circuit diagrams and printed circuit board pcb drawings are belong to. Author circuit after finishing a piece of a water pipe has been put into boxes …
Source: sm7ucz.se/Aktiv_antenn/Active_antenna.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18659.zip
PIC18F4550 USB Analog to Digital IO Board Visual Basic
IO board with PIC18F4550 microcontroller based on the pic accomplished many projects and have visual basic source code open source project müasit to their development PIC18F4550 analog input and digital input and output ports via USB port control a lot of reading done ..
