TEA2025B stereo Amplifier circuits
| Updated on August 4, 2019
the TEA2025B battery 6V stereo Amplifier circuits that will work with my goal of making an amp that could power enough and relatively practical.
In fact, this recipe is more Class D amfile and ready to comply with but is not because I don’t want to use the chance to get this out of my hands I headed Tea2025B eat.
TEA2025B circuit diagram
tea2025b-devre-tea2025b-isis-tea2025b-schematic-v1
TEA2025B Datasheet
tea2025b-datasheet
TEA2025B Test
To find a suitable box, a fairly simple schema and pcb with the boxing phase has completed.In this case the noise is not heard even the sound of the DIP of the night, and with the USB not 5-12v range, of course, a power boost can work with.
A small heatsink is needed, the cooler fits on the motherboard, thermal paste and old for this hot cut from a silicon stabilized at a level that will play with reluctantly much.
tea2025b-kutulu
1-tea2025b-anfi-tea2025b-datasheet-tea2025b-driver-120x120 2-tea2025b-anfi-tea2025b-datasheet-tea2025b-driver-120x120 3-tea2025b-anfi-tea2025b-datasheet-tea2025b-driver-120x120 4-tea2025b-anfi-tea2025b-datasheet-tea2025b-driver-120x120
tea2025b-pcb
tea2025b-pcb-2
tea2025b-pcb-3
TEA2025B Amplifier circuit belonging to the PCB, schema files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25415.zip
Publication date: 2016/04/21 Tags: ,
2 Comments “TEA2025B stereo Amplifier circuits
    Bright white LEDs with a single battery DC-DC converter
    the led with a single battery would be interested in a while. Find a suitable circuit and a couple of candle left to do puts, instead I thought we could take advantage of.
    The place even over the land of both water PCB SMD SMD because let’s face it now it’s designed as something called Yi. It was a lot of work because the eyes are not the same. Use a lighted magnifying glass during the assembly is not possible if I couldn’t have finished. Two side PCB with adhesive tape fixed to the table while also unsolder Yi. Otherwise, you can’t stay hard and was constantly moving.
    the
    Led DC-DC converter circuit
    TEA2025B Verstärker schaltungen
    der TEA2025B Batterie 6V Verstärker schaltungen, die Arbeit mit meinem Ziel, dass ein amp, der macht genug und relativ praktisch.
    In der Tat, dieses Rezept ist Klasse D amfile und bereit zu erfüllen, aber nicht, weil ich nicht wollen, um die chance zu bekommen, diese aus meinen Händen steuerte ich Tea2025B Essen.
