Switched Fast Battery Charger Circuit TEA1102
| July 16, 2023 Updated
A versatile circuit, ideal for technical services that do different mixed works, transformer etd29 winding directions used in the switching (smps) section, wire diameters are shown with pictures
Quick charge for Nicad, NiMH, LiION, SLA and Lead Acid batteries and accumulators 1.2Volt, 2.4Volt, 3.6Volt, 4.8Volt, 6Volt, 7.2Volt, 8.4Volt, 9.6Volt, 12Volt, 14.4Volt. For SLA and Lead Acid batteries Voltage limited charge and protection for voltage drop, excessive temperature rise (DT – DT for Nicad & NiMH)
There are full charge detection, short circuit protection and led indicators, there is also timing control for 4Ah 2Ah 1.2Ah circuit based on tea1102 hfc4093 hfc4020 integrated
TEA1102 charger Main Features
Quick charge Nicad, NiMH, LiION, SLA and Lead Acid batteries
Suitable for 1.2V to 4.2Ah plus LiION 3.6V, 7.2V and 14.4V 1.2V, 2.4V, 3.6V, 4.8V, 6V, 7.2V, 8.4V, 9.6V, 12V and 14.4V batteries.
Charges 6V or 12V SLA batteries from 1.2Ah to 4Ah.
Charges 6V or 12V Lead Acid batteries with any capacity over 1.2Ah.
Includes a discharger for Nicad batteries.
Additional charge at the end of fast charge, pulse trickle charge for Nicad & NiMH
Voltage limited charging for SLA and Lead Acid batteries
Voltage drop and temperature rise (dT/dt) full charge detection for Nicad and NiMH
Under- and over-temp cut-off for battery, Over-temp cut-off for Charger
Short circuit battery protection, Timeout protection, Fuse protection
Multi-LED charging indicators
Switched Battery Charger Project
TEA1102-fast-charger
TEA1102 Circuit diagram
tea1102-circuit-schematic
source http://www.siliconchip.com.au/cms/A_101812/article.html http://www.siliconchip.com.au/cms/A_101728/article.html
TEA1102 Fast Battery Charger Circuit schematic pcb files alternative links:
Published: 2009/02/04 Tags: ,
1 Comment “Switched Fast Battery Charger Circuit TEA1102
    PIC16F628A with Fast Battery Charge System (12V-6V Batteries)
    Microcontroller controlled A complete 12V 6V battery charging system battery charging circuit pretty powerful 16.6 amp 2xlcd with the display charging voltage, current and temperature can be observed (LCD display volts, amps heat a simple measurement circuitry may give an idea) software in assembly language prepared by the source. pic Asm. Hex files available
    PIC16F628A Fast Charge Circuit
