2+1 Amplifier Project using tone controls have the feature of entries 3 tda2050 ne5532 op amplar used 32w per channel power can give. Çaslışma symmetric DC voltage of the amplifier circuit 2x25v TDA2050 symmetric (transformer: 2x16v ac 100w) considering the power drop leg links is the same as the tda2040, can be used to control or filter or tda2030 lm1875 times you can use a different 2.1 amplifier circuits.
Source: mirley.firlej.org/wzmacniacz_stereo_z_subwooferem
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18919.zip
Publication date: 2012/05/16 Tags: audio amplifier circuits, ic amplifier
Tube Amplifier Project Fisher X100A
The next time I started the work and almost six months before the active paper, I finished my amp based on the Fisher working x100a.I need to do on paper for a long time, both in the supply circuit designs amp 2-3aylık at the end of the test phase of an application and a trunk and a very good result.
Many of you have heard the name of the brand, many of you have heard of American-made, maybe Fisher is one of the best konfigirasyonlarından almost serisiA class employee X100A El84 lamps and can produce about revised portions of the power amp, 18w, and did a very nice amp.
