Bridging 20W Amplifier Circuit TDA2005
| Updated on July 27, 2024
TDA2005 stereo integrated amp powering two kanel 2x10watt 20watt single channel mono bridge connection gives you the power. Between the supply voltage dc 18w 8v .
20w bridge amplifier for car radio
High output power : PO = 10 + 10 W@RL = 2W, d = 10% ; PO = 20W@RL = 4W , d = 1%. High reliability of the chip and package with additional complete safety during operation thanks to p.rotection against :
  • . output dc and ac short circuit to ground
  • . overratingchip temperature
  • . load dumpvoltagesurge
  • . fortuitous open ground veryinductive loads
schematic-tda2005-bridge-connection-20w-amplifier-circuit
Publication date: 2010/08/01 Tags: ,
1 Comment “Bridging 20W Amplifier Circuit TDA2005
    10W Amplifier Circuit TDA2003
    TDA2003 often used in car stereo amp car in the low-power integrated amp with very little additional elements can give a single channel mono 10watt power. Anfi … 10v 8v circuit operating voltage from a single source
    TDA2003 10W Car Radio Audio Amplifier
