TDA1562Q Stereo Amplifier Project
| July 7, 2023 Updated
Two 2×70 Watt Stereo Amplifier circuit TDA1562Q’ve done with PC ATX power box was mounted. looks fine.
TDA1562Q Amplifier Schematic Pcb
entegre_devre
PCB Material Layout Plan
tda1562q_pcb_ust
1: Audio input R
2: Audio input L
3: Feeding inlet Minus Chassis (-vss)
4: Supply inlet Plus + (+vcc)
5: Speaker output R
6: Speaker output L
pcb_
anif_kutu
anfi_kutu_3
anfi_kutu_1
TDA1562Q Stereo Amplifier Project proteus ares pcb files
Published: 2008/03/26 Tags: ,
1 Comment “TDA1562Q Stereo Amplifier Project
    N-Channel MOSFET Amplifier circuits
    N-channel IRFP260, IRFP450, IRFP240, IRF840 Mosfet Series with high quality power amp circuits have all the details (in English), especially in the picture 🙂 I liked TO220 and TO247 Cases have two different PCBs
    PCB Files ready printable PDF Formats available also Sprintlayout prepared by the Source. Lay extension PCBs dosyalarıda there in the circuit of the power supply output power according to the +-50v and + -90 volts is changing Be Careful All models symmetrical supply is working with
