TDA Series Audio Amplifier Book
| Updated on August 28, 2023
Philips company TDA series amplifier integrated to prepare a document has been on the market a lot tdaxxxx amp integrated detailed information about the (power, operating voltage, frequency, etc..) And televisions, stereos, audio systems for the circuit diagrams are summarized below was given
AUDIO AMPLIFIER ICS DESIGNER’S GUIDE
  • Product survey and page reference
  • In application sequence
  • In power output sequence
  • Audio amplifier ICs for portable radio/audio equipment
  • Audio amplifier ICs for car radios/power boosters
  • Audio amplifier ICs for mains-powered systems including hi-fi and TV sound
  • Appendices, Further information, Data
  • Application notes and leaflet
  • Index of audio amplifier ICs
tda1514a-mono-anfi
tda1514a-kopru-bridge
 TDA1010A/1020    Preamplifier plus 3,4 to 12 W power amplifier
 TDA1011    6,5 W amplifier
 TDA1013B    4 W to 10 W amplifier with DC volume control
 TDA1015    4 W amplifier
 TDA1015T    500 mW amplifier
 TDA1016    2 W power and record/playback preamplifier
 TDA1308T    2 × 60 mW headphone/line output driver
 TDA1510AQ/1515BQ    24 W BTL or 2 × 12 W amplifiers
 TDA1514A    50 W high-performance hi-fi amplifier
 TDA1516BQ/1516CQ/1518BQ    24 W BTL or 2 × 12 W amplifiers
 TDA1517(P)/1519    2 × 6 W amplifiers
 TDA1519A/1519B    22 W BTL or 2 × 11 W/12 W BTL or 2 × 6 W amplifiers
 TDA1521(Q)/2616(Q)    2 × 12 W hi-fi amplifiers
 TDA1521A/2615    2 × 6 W hi-fi amplifiers
 TDA1552Q/1553Q/1553CQ/1557Q    2 × 22 W BTL amplifiers
 TDA1554Q/1555Q/1558Q    2 × 22 W BTL or 4 × 11 W amplifiers
 TDA1556Q    2 × 22 W BTL amplifier with differential inputs
 TDA1560Q    40 W class-H amplifier
 TDA1561Q    2 × 23 W high-efficiency power amplifier
 TDA2611A    4 W to 10 W amplifier
 TDA2613/2614    6 W hi-fi amplifiers
 TDA7050(T)    150 mW BTL or 2 × 75 mW low-voltage amplifier
 TDA7052/7053    1 W/2 × 1 W BTL amplifiers
 TDA7052A(AT)/7052B(BT)    1 W/0,5 W BTL amplifier with DC volume control
 TDA7053A(AT)    2 × 1 W/0,5 W BTL amplifier with DC volume control
 TDA7056/7057Q    3 W/2 × 3 W BTL amplifiers
 TDA7056A/7056B    5 W BTL amplifier with DC volume control
 TDA7057AQ    2 × 5 W BTL amplifier with DC volume control
 TDA8541(T)    1 W BTL amplifiers
 TDA8542(T)    2 × 1 W BTL amplifiers
 TDA8543(T)    2 W BTL amplifiers
 TDA8547(T)    2 × 1 W BTL amplifiers with standby selection
 TDA8551(T)    1 W BTL amplifiers with digital volume control
 TDA8558(T)    Low-voltage BTL mono amplifiers
 TDA8559(T)    Low-voltage BTL stereo amplifiers
 TDA8560Q/8563Q/8563AQ    2 × 40 W BTL amplifier with diagnostics
 TDA8561Q/8564Q    2 × 24 W/4 × 7 W amplifier with diagnostics
 TDA8562Q/8565Q    4 × 12 W amplifier with diagnostics
 TDA8566Q    2 × 25 W BTL power amplifier with differential inputs
 TDA8567Q/8568Q/8569Q    4 × 25 W BTL amplifiers
 TDA8574(T)    Dual common-mode rejection differential line drivers
 TDA8577    Dual common-mode rejection differential line driver
 TDA8576T    Dual common-mode rejection differential line driver
 TDA8578(T)    Dual common-mode rejection differential line driver
 TDA8579(T)    Dual common-mode rejection differential line receiver
tda2615-tda2616-tda1521a-anfi-stereo-mono tda8579-anfi-amplifier-ses-tda
Publication date: 2010/01/23 Tags: , ,
1 Comment “TDA Series Audio Amplifier Book
    L200 LM2577 Regulated Lithium Polymer Battery Balance Charger Circuit
    Specifically, model, model jobs for people dealing with the charging circuit is very important to work in a makette electronic systems used in Cordless batteries now models lipo (lithium polymer) are popular.
    This charger for charging the batteries evenly balanced circuit must balance balancing system the following circuit with 3 pieces of lipo battery rechargeable current limitation I have switched to fast-charge and charge indicator.
    13.6 V where we get good, that is where the circuit comes first solution, we use an elevator to the LM2577 voltage switching
