The high voltage generator circuit electro shock device has a low power and simple circuit design. There are 3 versions with transistor, opamp, ne55 trigger, you can use ee16 for the transformer used in the circuit, this transformer is available in pc power supplies (tl494 output driver) transformer winding information electro shock device schematics and other details are given.
ATTENTION Portable high voltage generator HV Generator circuit produces high voltage, be careful, although the current power is low, high voltage is harmful, do not touch with your hands during testing and operation
Mobile Shock Device Series:
Mobile Shock Device I:
This device is really small (10cm x 5cm x 3cm). It produces sparks with a length of 5mm to 10mm at high power. The output voltage must be greater than 8kV, because I closed an 8kV limit with this unit! WARNING: It is really painful to touch the contacts (in the upper part of the picture) and press the “fire” button (I tried it myself… the 2uF cap only charged to 500V. I am not crazy enough to touch the contacts after that. The 2uF cap is charged to 740V)
Basically, I discharge a 2uF @ 740V cap through a self-made ignition/trigger coil.
The coil (Tr2) has a ferrite core that is 4cm long and 1cm in diameter. The primary side of the coil has 15 turns of 1mm wire. The secondary side has about 400 turns of thin wire. I wrapped the secondary winding over the primary windings. I used a lot of insulation tape between each layer of the HV windings. There is a shrink tube and insulation tape between the primary and secondary layers.
Mobile Shock Device II:
This circuit automatically generates HV Pulses because it has an automatic trigger circuit. The output voltage is lower than the output voltage of the first mobile HV-Pulse Generator because I used a smaller cap. This circuit is easier to build than the first version because you will need fewer parts.
higher firing frequency => looks like a spring
better and smaller oscillation circuit => more space for other things
the circuit fires after reaching a certain voltage => no need for voltage regulation circuit
less output voltage but higher firing frequency
Mobile Shock Device III:
The transformer is the same photoflash transformer that I used for Mobile HV Generator I and II.
None of the parts values are critical. Transistors: for BD135 with a capacity of 2A and about 45V you can use any NPN transistor. For PNP transistor with a capacity of 2A and about 45V you should use fast switching type. Voltage doubler caps: capacitance is NOT critical! You can use any cap you can find with a capacitance of some nF. If the 36kOhm or 10MOhm resistance values are not correct, there is no problem => The maximum output voltage will be less than or higher than 1500V.
Source: kronjaeger.com/hv-old/chauer/mobilehvgen/index.htm alternative link:
Published: 2011/05/29 Tags: power electronic projects, tl494 circuit
Automatic Rabbit Feeding System ATmega8 Timer
In fact, feeding, feeding various timing circuits used for business. Generally puzzling, time-consuming mechanical parts is getting no special circuitry to rabbits in this project but the authors have used to feed rabbits 🙂 crafted with a software pascal Pascal example might be for users.
Circuit based on Atmel ATmega 8 2 × 16 LCD also displays information on the source code of the circuit prepared with eagle pcb, diagram drawing there.
