Previously, “Night Lamp with White Led, 20 pcs economical lamp with white LEDs project and 220volt with 19 pcs white LED energy saving lamp practices were shared’ll talk about saving bulb on the application made by removing the original parts.
Half-6 white LEDs used LEDs on the power supply directly to 220v mains voltage are taking over the 220v mains voltage 2 3.9k 5w resistor delimited by the bridge diodes with doğrultuluy the 4.7uF 400volt with the capacitor is filtered and 2.7km 5w stone resistance delimited by LEDs are applied.
White Led Bulb
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
Source: http://www.neoteo.com/diy-lampara-de-bajo-consumo-led.neo”>http://www.neoteo.com/diy-lampara-de-bajo-consumo-led.neo
Microchip PIC Examples Assembly Project
All source code, libraries, and other files, complete with diagrams practices Microchip PIC assembler’s eight projects. In particular interface applications can be useful for different projects.
