Image processing robot project was in an advanced robot is said to be 100% win rate 🙂 Robots terms of the human hand to the wrist, the hand moves to be made according to the position sets. The robot can recognize the hand shape in a very short time and is making moves.
Test video of the robot;
Source video: http://www.k2.t.u-tokyo.ac.jp/fusion/Janken/janken.wmv
Publication date: 2012/07/17 Tags: technical video
TDA7294 Amplifier Circuit Small PCB
In addition, you can use TDA7294 and a lot of similar symmetrical feed circuit of the amp pcb circuit 2x 10.000uf promise in çizimini 63v capacitor and diode bridge can be used in addition to 10 amp fuse holder KBU10M load resistors and 2 LEDs have 100nF. As the power amplifier circuit is not very thick flowing roads TDA7294 circuit than enough, but if you use a high-powered applications that use PCBs or thinner copper plaque with the cover of this circuit solder Paths
Stein Papier Scissors Spiel Unbesiegt Roboter
Bildverarbeitungsroboter-Projekt wurde in einem fortgeschrittenen Roboter soll 100% Gewinnrate sein 🙂 Roboter Begriffe der menschlichen Hand auf das Handgelenk, die Hand bewegt sich entsprechend der Position gesetzt wird. Der Roboter kann die Handform in kürzester Zeit erkennen und bewegt sich.
