Arm Sumo Robot Project STM32F4
| Updated on August 3, 2019
Discovery ST Microelectronics ARM development STM32F4 production, based on experiments card to mini-water robot project that makes working with ARM beginners a good example for people TB6612FNG used for dc motor drive is used as a sensor Sharp GPY0D340K ..
arm-robot-suma-robot-stm32f4-robot
“KAVSA” mini sumo using ARM processor, an ARM platform software development experimental mini-sumodur. PİC micro controller, nowadays almost all robot makers refers to the first kontrolördür. The fall of the ambient conditions, the magnetic field and the PİC voltage overload causing to Reset affected by vere. PİC’s for those who think that the border would be a good choice.
We’re not used to seeing robots and more fitted, we wanted to use the wheel. But of course this is embedding a design into almost all of the motor wheel.
Source: kasvaminisumo.blogspot.com alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19236.zip
Publication date: 2012/07/13 Tags: ,
2 Comments “Arm Sumo Robot Project STM32F4
    Power Led Driver Circuit LNK419EG 50V Switch Mode Power Supply
    Power Integrations is constantly developing new integrated SMPS control is doing very well in light of the documentation. Temperature, harmonics, power and so on. All test reports of the SMPS transformer winding circuit gerber files, including information gives everything. 23W LED Driver LNK419EG based on this integrated series of linkswitch-PH LED driver ICs in this series, dimmer and so on. is used in applications
    Arm Sumo Roboter Projekt STM32F4
    Discovery ST Microelectronics ARM Entwicklung STM32F4 Produktion, basierend auf Experimenten Karte zu Mini-Wasser-Roboter-Projekt, das die Arbeit mit ARM Einsteiger ein gutes Beispiel für Menschen macht TB6612FNG für DC-Motor verwendet wird als Sensor Sharp GPY0D340K verwendet
