STK4172 PCB STK4182 PCB STK4192 PCB
| Updated on August 3, 2019
Production from Sanyo STK series STK4172, STK4182 STK4192 amplifier and i prepared a PCB drawing connections compatible with one leg of an integrated
2x40W THD 0.4% Operating voltage 2X48V STK4172 STK4182 STK4192 2X50V 2X45W 2X50W THD 0.4% Operating voltage Operating voltage 2X52.5V
sanyo-stk-amplifier-stk4172-stk4182-stk4192
The STK4102II series (STK4172II) and STK4101V series (high-grade type) are pin-compatible in the out-put range of 6W to 50W and enable easy design. Small-sized package whose pin assignment is the same as that of the STK4101II series Built-in muting circuit to cut off various kinds of pop noise Greatly reduced heat sink due to substrate temperature 125°C guaranteed Excellent cost performance
STK4172 STK4182 STK4192 PCB (.doc, .cdr):
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19748.zip
Publication date: 2012/09/14 Tags: ,
2 Comments “STK4172 PCB STK4182 PCB STK4192 PCB
    PIC32 Spectrum Analyzer Circuit TFT PIC24 PIC32 Examples
    Spectrum Analyzer application PIC32 series from PIC32MX360F512L performed by imaging the 3.5 TFT LCD (16.7m. Color) 320X240 screen using software Microchip MPLAB C32 compiler prepared with ssd192x driver (SSD1928L Drivers) includes all the source code there is also the FFT aligrot the code through’s. The project was carried out in this module by module scheme LVC75Z779 there (no PCBs) analyzer to test the computer’s sound card, MP3 player or other audio source can be used.
    PIC32MX360F512L Spectrum Analyzer implementation of the material terms can lead to difficulties, but the source code driver files for different projects is very useful also PIC24F series for the 2.4, 2.8, 3.5 TFT LCD and have different applications, all of the source code and drivers are available and used PIC24F experiments set schema, there
    STK4172 STK4182 STK4192 Leiterplatte
    Produktion von Sanyo STK-Serie STK4172, STK4182 STK4192 Verstärker und ich bereitete eine PCB Zeichnung Verbindungen kompatibel mit einem Bein eines integrierten
    2x40W THD 0,4% Betriebsspannung 2X48V STK4172 STK4182 STK4192 2X50V 2X45W 2X50W THD 0,4% Betriebsspannung Betriebsspannung 2X52,5V
