Speaker Cabinet Designs Diagrams Schematics
| July 2, 2023 Updated
If you want to make your own cabin for Anfi with details galore “Speaker Cabinet” design there. Bass, treble filter media used in the cabinet (crossover) available with the transferor. Many “Speaker Workshop” program and detailed designs prepared quite well (. Swd files)
kabin-bass-tiz-md bass-tiz-crossover
speaker-workshop kabin-iki-yollu
kabin-medyum-tiz
Speaker, Cabinet Designs All Files :
Speaker Cabinet Designs Diagrams Schematics dw link
Published: 2008/01/13 Tags:
2 Comments “Speaker Cabinet Designs Diagrams Schematics
    Isolated gradual Dimmer Circuit
    Lamp Dimmer, motor speed, you can use applications such as soldering iron temperature control dimmer circuit
    220 volts (AC)’ll be retrieving landing device for control of the isolated dimer 100w Stage. MOC3040 Opto isolated diac provided with a selective process and control triac BT136 used without coolant CD4001 CD4017 integrated use of
    CAUTION dimer is working with high voltage circuit capacitor connection Observe caution + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
    Wenn Sie Ihre eigene Kabine für Anfi mit vielen Details herstellen möchten, können Sie dort „Speaker Cabinet“ entwerfen. Filtermedien für Bässe und Höhen, die im Gehäuse (Frequenzweiche) verwendet werden, sind im Lieferumfang des Transfers enthalten. Viele “Speaker Workshop” -Programme und detaillierte Entwürfe recht gut vorbereitet (.SWD-Dateien)
