Handmade SMD Microcontroller Programming Socket
| Updated on June 18, 2014
For programming I integrated SMD usually on the legs if I have thin wire soldered on the PCB with SMD edition of pegs with integrated pull cable programs of the ways I squeeze PCBs
Handmade SMD Microcontroller Programming Adapter
smd-soket
smd-entegre-soketi
Cercleferronancy author on the site prepared for the hand-made integrated SMD shared socket socket to program PIC12F629 using the super workmanship make time to do a really nice design tutorials are available here 🙂
Publication date: 2009/10/08 Tags:
1 Comment “Handmade SMD Microcontroller Programming Socket
    PIC16F84 RF Fish Detector Circuit
    Circuit second part consists of water released into the rf-makers and the information will appear RF-receiver circuit two circuit pic 16f84 micro-controller based on the pic “Reed Relay” use and relay operation rf to convey a sample project also modules source MPLAB files (asm, hex, etc.).’s top to bottom in pdf format PCB, circuit diagrams have a list of materials
    4 red LEDs and buzzer on the RF receiver circuit with the signal status can be monitored. Author of the circuit to detect fish under the water for balIkcIsI mention that 🙂 transmitter circuit must be watertight boxed says.
