to prevent problems that might occur as a result of instant loading lamps, incandescent bulbs give instant light as soon as many of us classic and opened an exploded thanks to that we’ve seen a simple circuit that it’s broken, we can get ahead of these defects substantially
Slow startup is going full time in about 3 seconds, the circuit is reset when the power goes off within 30 seconds after a time when you did open the door so that the lamp won’t start continuous slow warming already in Flemish it’s not really necessary
soft start incandescent bulb
note BT136 triac used in the circuit-high voltage do not touch the outer casing screwing 600E region that is associated with the partition do not allow any part to contact. Operates with a high voltage capacitor circuit connections caution notice + – reverse polarity if you connect to the circuit line may be large explosions before running the insured electricity at high voltage,protective eye glasses
Connect to line voltage section of the circuit that need your attention, except that the phase 220V, 150W lamps and BT136-600E triac must be connected to the cooler
source: cxem.net/house/1-375.php
Published: 2016/04/22 Tags: power electronic projects
PCB spark gap
@Bülent NUR forwarded by my teacher PCB spark gap videosu review, especially in power electronics PCB designs contains useful information for possible leakages on the system high voltage spark gap for a method to be applied to minimize damage thanks @Bulent
Langsamen Anfang-Schaltung für die Glühlampe
um zu verhindern, dass Probleme, die möglicherweise auftreten, als Ergebnis der sofortige laden von Lampen, Glüh-Lampen geben sofort Licht, sobald viele von uns klassische und öffnete eine explodierte Dank, dass wir gesehen haben, eine einfache Schaltung, dass es kaputt ist, können wir weiter kommen, diese Mängel wesentlich
Slow Start wird in Vollzeit über 3 Sekunden, die Schaltung wird zurückgesetzt, wenn der Strom Weg ist innerhalb von 30 Sekunden nach einer Zeit, wenn Sie Tat die Tür öffnen, so dass die Lampe nicht starten kontinuierliche langsame Erwärmung bereits im flämischen es nicht wirklich notwendig ist
