We provide a simple and very inexpensive realizable Light organ for fast Plug & Play before use, the lamps with an output of up to 300 W “power” can. The control of the light organ is performed by a built-in microphone.
That the timelessly popular light effect units not always large, expensive and tedious must be installed, which shows here example presented – a small light organ quasi for home use. The in practical plug and socket housing accommodated device is a Plug & Play Lighting effect, it is enough to start the simple plugging into a power outlet and attaching an almost any incandescent lamp up to 300W Power consumption. So at the party, virtually any Light in the room that would otherwise be silent before him lit for effect light are!
Power supply
230 V/50 Hz / Max. 1.6 A
Output: Max. 300 watts
Control: internal microphone
Dimensions: 32 x 67 x 40 mm
CAUTION The circuit works with high voltage. Be careful, pay attention to the capacitor connections. If you reverse the + – poles, there may be large explosions at high voltage, before operating the circuit, use the Insured Power Line, protective glasses.
230V 300W Lamp Sound Control schematic
Publication date: 2008/10/10 Tags: power electronic projects
8051 Stopwatch Circuit with Lcd Display
Stopwatch Circuit 8051 on behalf of the programming of integrated compiler program that is used too much in the present case. You are left with only the easiest to use and most advantageous for you to choose. 8051, which can be programmed Uvısıon2 KEIL compiler is without a doubt the most advanced ones, I think.
8051 Stopwatch Schematic
