The use of voice-changing circuit will sound interesting and fun changing the tests gives the circuit except for the passive elements in shades of Danılt Min ca3240 (bimos op amp) and the tl072 (jfet input opamp) based on clean and effect by setting the potansiyometreleri op evening sound is being changed. The circuit can be connected to the headphone output or a simple amplifier circuit.
Circuit diagram by examining different by changing the values of resistors and capacitors used in Op amplarda audio tones can be achieved.
You can listen to the author’s attempts to flash player;
Source: staff.uni-bayreuth.de/~btp918/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16080.zip
Published: 2011/09/02 Tags: audio control circuits
100W Car Amplifier Circuit TDA7293 TL494 DC to DC ETD29
Car amplifier mono 100w power amplifier tda7293 floor (the 100w 120v dmos) IC dcdc converter section tl494 (pwm control) used. Adding audio input filter can be used as a bass amp. Used in the primary winding of the transformer Transformer ETD29 DCDC 1.2 mm wire 2 × 6, 2 × 0.8 mm wire of the secondary winding of round 21 tour hug.
