Relay IR (infrared) Sensor Circuit infrared Transceiver (tested)
| August 24, 2023 Updated
IR Sensor transmitter and receiver circuit consists of 2 parts as 250Hz 38kHz oscillator signal with the transmitter produces solid CD4093 receiver with IR LEDs on the receiver transmits a simple relay circuit works can be found in all parts market
There are 25 meters sensing distance listesiv supply voltage of 12 volts DC supplies a detailed explanation (in English) have also been made with the transmitter integrated circuit NE555 is in a state.
Door-Minder-
Receiver circuit diagram
alici-devre-semasi
The transmitter circuit diagram CD4093
verici-devre-semasi-cd4093
The transmitter circuit diagram NE555
verici-devre-semasi-ne555
Door Minder circuit alternative links
Published: 2009/11/16 Tags:
1 Comment “Relay IR (infrared) Sensor Circuit infrared Transceiver (tested)
