ROT-KON-1.0 is a general robot control board. Most of what we want with ROT-KON-1.0 robot is designed according to the project. ICSP connector on the program include throwing socket and bootloader. Also Aport male connector portion is connected sequence of sharp GP2D12/GP2D15 sensor is designed according to the sequence of the pin.
B port is part of the male connector pin sequence of the mini servo motor circuit in accordance with tasarlanmıştır.ancak D3, D4, D5, D6 diode bridge with bell wires instead of making will be more healthy . There are four buttons, one pull-up resistance .
Actually sing buzzer circuit is designed to short-circuit . Namely porta.4 buzzer is connected to the first circuit works here because it is TOCK on the current through the resistor r4 buzzer beeps and silence we are would be zero by typing it into the program . Half a short circuit condition when the pic self- reset will take pic and its all reset at us when porta.4 to zero, we took command without seeing the pic himself a more hard reset will and buzzer never stop will be in this case, the circuit is shorted card your own news gives .
7805 and in cooler parts of the L298 is aligned so that it only collected in the cooler . Robot friends in the ROT-KON-1.0 the intended user would like to thank in advance .
Robot Development Robot Projects circuit, pcb files:
Published: 2011/01/03 Tags: avr development board
Weekly Scheduled Watering Flowers Circuit PicBasicPro PIC16f876
I applied before the project @ ferhatyol friend revealed is a modified version of the project. 3 irrigation functions available in the program. Applications for pic16f876 microcontroller based on the 2 × 16 LCD screen display software that was used was prepared by PicBasic pro
LOW (0-20sec) Meduim (21-40s) HIGH (41-59sn) circuit menu in English and saaat (TIME) When enter settings without setting can climb.
