Proteus isis Library Model Archive-1
| July 7, 2023 Updated
Proteus simulation program, it just works 🙂 especially as I’m trying to learn programming in PIC: D not only PIC `s other analog circuits, digital circuits in the material library is good, but insufficient LM317T regulator was required for a project of this basic protes:)
but you could not find in the library occasionally none that would work a lot of models, and sample library. Dsn files found Files that are installed on your system before you try and library file, Proteus model of the backup copy of the program
Adding Proteus Library
It is very easy to add new proteus library files in the Proteus program. We copy the “.IDX” and “LIB” extensions in the file to the “LIBRARY” folder in the folder where the proteus program is installed.
Note: After this process, take a backup of the “LIBRARY” folder, you can restore it in case of any problem. Files such as .MDF, .DLL, .SML, .LML are copied to the “MODELS” folder.
If Proteus v7 is installed:
into the C:\Program Files\Labcenter Electronics\Proteus 7 Professional\LIBRARY folder
If Proteus v8 is installed:
C:\Program Files\Labcenter Electronics\Proteus 8 Professional\LIBRARY (for 32-bit OS)
C:\Program Files (x86)\Labcenter Electronics\Proteus 7 Professional\LIBRARY (for 64-bit OS)
proteus-library-add-proteus-kutuphane-ekleme
proteus-library-add-idx-lib-proteus-kutuphane-ekleme
Proteus isis Library Model download:
Proteus isis Library Model Archive-1 dw link
Ĺžifre-Pass: 320volt.com
Published: 2008/03/24 Tags:
1 Comment “Proteus isis Library Model Archive-1
    AV800 800W Power Amplifier Circuit Mosfet IRFP9240 IRFP240
    The cost is high 🙂 output stage 14 (IRFP240 IRFP9240) Total Supply voltage MOSFETs used quite high +92 V-92V Be Careful
    The 800 Watt AV amplifier is based on My 1kw Amplifier and shares the same topology and basic PCB layout. The only real difference is the number of Output devices that the unit uses. The 1kw design has 20 O/P devices, while the AV amplifier has 14 O/P devices. This amplifier can be used for practically any application that requires High power, low noise, distortion and excellent sound. Examples would be Sub-woofer amp, FOH stage amplifier, one channel of a very high-powered surround sound amplifier etc. The AV amplifier has four main stages of amplification. We will begin by looking at each stage in reasonable detail.
