SMD type resistor, capacitor, diode, or the like in the case of removal of the material very practical for Iron soldering apparatus you can prepare and see your work in a short time. As shown in the video picture and the material used is 2mm thicker pieces of copper wire with more advanced easier to handle some of the labor required to actually care.. SMD apparatus can be done.
source: runawaybrainz.blogspot.com
Published: 2016/04/23 Tags: technical video
Color Detection Circuit PIC18F252
In the new version issued to 10 The number of colors, color identification and color separation feature was developed and added to a method for the sensitivity has been increased. Also feature full contact with the surface to be detected with the sensitivity calibration and the requirement has been removed. Color Sensor detection circuit, located on 5 different colors of LEDs in 16 different combinations and can be activated with different colour shades with light illuminating the surface to be detected of the reflected light in the form of making separations and evaluate the impact on the LDR works.
Praktische SMD Entfernen
SMD-Art Widerstand, Kondensator, diode, oder wie im Fall der Entfernung des Materials sehr praktisch für den Eisen-Löt-Apparat, die Sie vorbereiten können und sehen Sie Ihre Arbeit in kurzer Zeit. Wie in dem video gezeigt Bild und das verwendete material ist 2mm dickeres Stück Kupferdraht mit mehr erweiterte einfacher zu handhaben ist einige Arbeit erforderlich, um tatsächlich egal.. SMD-Apparatur durchgeführt werden kann.
