There are alternatives on the market with 4 TR2516T1 ultrasonic transmitter plow transmitter 25kHz 16mm dimensions, the output of which is installed on the CD4093A integrated circuit of the ultrasonic dog repellent circuit, powered by BSS88 mosfets.
Output peak voltage can rise up to 85-90V, frequency adjustment can be made with R1 trimpot. In the SMD pcb version of the dog repellent circuit, the frequency setting resistance is used as a fixed 15k (5k and 10k connected in series).
It is suggested to use a quality alkaline battery with supply voltage of 9v battery. The feeding of the CD4093 door circuit was provided with 7805 regulator. Current consumption of the circuit is between 100ma… 110ma Note: 3 ultrasonic transmitters are used in SMD pcb version.
Ultra sonic Dog Repellent Circuit Diagram
ULTRASONIC DOG REPELLENT PARTS LIST:
DD1.1-DD1.2-DD1.3: CD4093
SR1: 7805 REGULATOR
T1-T2: BSS88 MOSFET TRANSISTOR
D1-D2: UF4007 FAST DIODE
LED1: 3MM OR 5MM LED
TR2516T1 4 PIECES (THE MOST CRITICAL MATERIAL THAT 25KHZ TRANSMITTERS, 40KHZ WHICH HAVE PILLARS IN THE MARKET MAY NOT WORK DATASHEET:
sensorelement.com/ut/Open%20type.pdf)
BAT: 9 VOLT BATTERY
100MA: 100MA INSURANCE
S1: PUSH BUTTON
L1-L2: 1 MH FERITE COIL
L3-L4: 4.7 MH FERITE COIL
R1: 15K RESISTANCE OR 15K TRIMPOT
R2-R3: 100 OHM RESISTANCE
R4: 5.6K RESISTANCE
C1: 4.7NF CAPACITOR
C2-C6: 100NF CAPACITOR
C3-C7: 100MF 16 VOLT CAPACITOR
C4-C5: 2.2NF 250 VOLT CAPACITOR
source: radiokot.ru/circuit/digital/security/44/
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-26397a.zip
Publication date: 2020/02/06 Tags: analog circuits projects
Répulsif ultrasonique puissant pour chiens
Il existe des alternatives sur le marché avec 4 émetteurs de charrue à ultrasons TR2516T1 de 25 kHz 16 mm dont la sortie est installée sur le circuit intégré CD4093A du circuit ultrasonique répulsif pour chiens, alimenté par des mosfets BSS88.
La tension de crête de sortie peut monter jusqu’à 85-90V, le réglage de la fréquence peut être effectué avec le trimpot R1. Dans la version PCB CMS du circuit répulsif pour chiens, la résistance de réglage de fréquence est utilisée comme un 15k fixe (5k et 10k connectés en série).
Il est conseillé d’utiliser une pile alcaline de qualité avec une tension d’alimentation de pile 9v. L’alimentation du circuit de porte CD4093 était fournie avec un régulateur 7805. La consommation de courant du circuit est comprise entre 100ma… 110ma Remarque: 3 émetteurs ultrasoniques sont utilisés en version pcb SMD.
Diagramme de circuit répulsif ultra sonique pour chien
