Pickit2 ZIF Adapter Module PCB
| September 7, 2024 Updated
Especially in the original Pickit2 Clone programmer ZIF socket adapter will work PICKIT 2 programmer circuit clone copies all of the original device in the ZIF socket but the ICSP programming jobs out there, it becomes a bit easier thanks to the adapter.
Adapter pcb layout drawings have been nice preparing quite well gatox-h4
pickit2-adapter-icsp-socket-zif-120x120 pickit2-adapter-icsp-socket-zif-pcb-120x120
pickit-2-adapter-zip-40-pin-platine-layout-pcb
Published: 2011/05/20 Tags:
1 Comment “Pickit2 ZIF Adapter Module PCB
    Handmade Drill bits Syringe Needle
    For a long time I have found a method that I use and own both practical and pretty cheap as well, for me, better than any other drill bit
    Show some advantage;
    7 injector syringe needle with 50 kr note: injector syringe must be bought from the smallest.
