The project is to use dsPIC33F controller with many embedded peripheral modules, and this family controller is applicable/perfect for muti-purpose controlling.
This project is full construction of mini puppet theater with computer control. dsPIC controls lightings and motion of Pinnocio charecter by controlling motors to pull strings that make the character alive. Microchip Part in the project: dsPIC33FJ256MC510: (qty 2) TC4427 MOSFET driver (qty 5) EEPROM 25LC256 (qty 1)
MPLAB v7.52 C30 Compiler v 3.01 This is the main function for the BLDC application. This code calls the setup routines, initializes system variables and parameters, enables interrupts, and then goes into a polling loop. The main polling loop clears the WDT and runs the medium (10msec) and slow (100msec) event handlers when appropriate. Authors: Nghia Tran, Victor Tran, Tammy Tran, Andy Tran and Mai Nguyen
Published: 2010/05/24 Tags: dspic projects, microchip projects, microcontroller projects
dsPIC30F301 laser light backscatter lcd keypad input
Microchip 16-bit Embedded Design Contest Determining Surface Roughness By Laser Light Backscatter Registration Number – MT2254 October 16, 2007 As a stand alone measurement system with user interaction, the project needs some sort of intelligence. A Microchip brand dsPIC microcontroller was chosen to provide this intelligence.
