PIC30F2010 dsPIC controller 2 axis midi laser show
| July 26, 2024 Updated
This project is a dsPIC30F2010 based controller for a two axis laser show. The controller receives input as MIDI data, and controls X and Y beam deflection mirrors attached to open loop scanning galvanometers. PWM square waves don’t make very good galvo drive waveforms. The dsPIC30F series, however, is fast enough to both decode the required MIDI instructions and output the waveform data via the SPI bus to a MCP4822 DAC Author: Scott Coppersmith
dsPIC30f2010 MIDI Laser Show Galvanometer Controller Circuit Cellar MicroChip 16-bit Embedded Control Design Contest 2007 Project Registration Number MT2163 In this example program characters pressed on the keyboard are sent to the device via usb. The device replicates the character back to the PC enclosed in quotes. Also this program blinks all four LEDs at 250ms by using timer 1
Published: 2010/05/24 Tags: , ,
1 Comment “PIC30F2010 dsPIC controller 2 axis midi laser show
    PIC24FJ64GA002 cellular phone emergency auto dial
    PIC24FJ64GA002 Microchip 16-bit embedded control design contest 2007 project registration no. mt2249 project name : a fixed cellular phone with emergency auto-dial this application has been compiled on mplab tools v7.62. only this version of mplab tools allows the complete build of this program any version below v7.62 has some bugs that donot allow build on the 24fjxx series. the same has been recommended by microchip we have used mplab icd2 debugger for this project
