Use ADNS2610 Optical Mouse Sensor PIC18F4550 USB
| Updated on July 25, 2024
Adns2610 interesting optical mouse sensor circuit out of the detected motion is displayed on a computer screen. PIC18F4550 USB connection on the circuit board are available.
Normal mouse but sees his job applications were done with PIC and MPLAB file that contains resources for different projects to be developed, it might inspire
Mouse Sensor Circuit PIC18F4550 ADNS 2610
Basis for this project is PIC testboard I also used for the other USB projects and the TV-Light. I created it myself on the basis of this project. The software is based on the HID demo from Microchip and has been adapted to interface the sensor instead of using a fixed mouse movement. The complete MPLAB project can be downloaded here for usage according to the terms of the original Microchip project. The sensor itself is interfaced using the SPI protocol (see the sensor’s datasheet).
circuitToPic
Source: http://www.steffenschuette.de/steffenschuette/elektronik/myMouse/myMouse.htm ADNS2610 PIC18F4550 USB circuit Alternative link:
Publication date: 2010/05/20 Tags: ,
1 Comment “Use ADNS2610 Optical Mouse Sensor PIC18F4550 USB
    Atmel AVR Programmer USB Circuit Atmega8
    Via the USB port of your computer that you can program Atmel series microcontrollers ISP port with stylish design a programming circuit.
    Prepared with eagle pcb circuit usb programming. are schematic drawings. To use the circuit to inspectors ATmega8 avr-doper-mega8-12mhz_a.hex need to download the file.
    Atmel AVR USB Programmer
