The “PIC18F452 Serial RS232 port connected control card” application was sent by Hasan Yetik from the Project Article Sharing section, I thank him. The application has source codes and isis simulation files written in C language.
PIC18F452 Control card with serial RS232 port connection
The main purpose of this card is to enable Gumstix to communicate with the outside world, but the serial port can also be used with all devices.
This card provides 8 x2 bit digital outputs, 2 PWM outputs and 2 ADC inputs according to the information it receives from the serial port. It can also send information to other devices with 2 serial port tx outputs.
It can be developed and used for different purposes. Copying and changing is free. You can visit my site as a Turkish resource for embedded Linux systems, hyetik.wordpress.com
RS232 Control Board Circuit
author Hasan Yetik – PIC18F452 RS232 control card application source files belonging to the;
Published: 2010/05/11 Tags: microchip projects, microcontroller projects
LCD Display PIC16F84A Temperature Fan Control Circuit
Previously shared “PIC16F84 and DS1621 temperature measurement and temperature control relay” circuit’ve implemented the project is working smoothly.
Proteus isis simulation study ds1621.dll file in the file C: \ program files \ Labcenter Electronics \ Proteus 7 Professional \ models with the same file inside the folder you need to change
PIC16F84A LCD display temperature
