LCD SWR Meter Circuit PIC16F877
| September 7, 2024 Updated
SWR meter circuit pic16f877 microcontroller with lcd display displays the information on a printed circuit board with 2 × 16, schema diagrams in the C source code library files (adc. c, lcd8 c, swrm. c, timers), and I have 2 different hex code for 16f877a 16f877
SWR meter Features:
Power range 5 to 100 W
Frequency range 1 to 30 MHz
Peak hold display operation for SSB operation.
Several basic screens showing Forward, Reverse, net outgoing power and SWR
Dual bar graph display for forward and reverse power
Large and clear 2*16 character LCD display
Simple two button interface
Hi SWR warning and alarm LEDs
Separate display and SWR bridge units. No antenna cable routing to the meter.
SWR-Meter-circuit-pcb-lcd-Display
SWR-Meter-circuit-pcb-lcd-Display-swrmetre-devresi
Digital HF Power-SWR Meter
This power-SWR meter is designed for 5 to 100 W ranges, but you can build a heavier measuring bridge and scale instrument for the range you want. The current version of the software provides several basic screens. Scaling and other feature setup parameters are in the software code (no setup menus).
You can install and test the SWR bridge and meter section separately. The SWR Bridge can be tested with a voltmeter and display unit with 0 to 10V psu.
SWR bridge
The critical component is the transformer L1. L1 is a 10-turn bifilar wound on the Amidon FT50-43 core. First twist two 0.4 mm wires together, and then wrap 10 turns evenly distributed on the core. The primary (TX to antenna) is the only wire passing through the core. The wire can be just straight wire or the other end of the grounded braid is fine coaxial. For safety reasons and better performance, it is wise to mount the SWR bridge board in a metal enclosure.
SWR meter Display unit
The display unit is built around the Microchip 16F877A processor and the Solomon LM1125SYLU1 LCD display. The Microchip 16F877 (non-A version) is also supported, but there is no LCD backlight control. The only critical components on the display board are the resistors R2, R3, R5, R6 and IC2. The display unit PCB is designed to allow separation of the pushbutton switches and SWR warning LEDs if your enclosure selection requires it. The backlight current generator fet Q2 may require additional cooling if the operating voltage exceeds 10 VDC.
SWR meter Software
The project was built with the Hi-Tech PICC compiler. It is not strictly ANSI C, but with some work the project can be ported to another environment. This initial test version does not include any user setup functionality. All setup and calibration variables are in the software code. The displays are not carefully planned, they only show the basic information needed. Things may improve in the future.
Source: http://www-diyhome.blogspot.com/
Published: 2011/03/19 Tags: , ,
3 Comments “LCD SWR Meter Circuit PIC16F877
    Non-Isolated AC-DC Converter LNK302P Buck Boost LED Power
    Non-Isolated Converter circuit mains voltage half wave input voltage available 85v rectification … 265v ac especially suitable for white LEDs run already in practice 12 white led on led run of the circuit performance focused plowed.
    The biggest advantage of insulation of the circuit (lnk302p) as shown in the diagram, the lack of mains voltage dez with direct connected transformer is obsolete, but the resistors, capacitors made by using a healthy circuit than 220v circuits regulate
