Satellite finder SatLock name as an applied project is going, but I’m not sure Does it work? I do not know, but a good example of the contents of 128 × 64 graphic LCD with PIC16F877 (A-2ylg mt12864) and use the tuner satellite receiver (d7g2121 tuner) communication with the pic and have a lot of detail
Following the 46-page thread on each page different shares there also some satellite receiver SMPS supply ENABLED given in MPLAB crafted with code files and sparint layout program with which you can open pcb spline with the program you can open the Satellite Finder schematic drawings available
Digital LCD SatLock Satellite Finder Project
Satellite Finder Circuit PIC16F877 Digital SatLock schematic code files:
Published: 2009/03/03 Tags: microchip projects, microcontroller projects, pic16f877 projects
ATX Power Supply Tester Circuit
ATX power supply led indicator and a simple circuit to test the output voltage of the LEDs, you know the observations made with the sprint pcb layout (.lay) located in drawing on the source site also has plenty of high-frequency transceiver circuits
Simple ATX Power Supply Teste
