NiCd NiMH Charger Circuit The accu cycler project presented here is an excellent solution for charging and discharging NiCd and NiMH accumulators for R/C modelers and others who make use of these accumulator types. With its performance it is very close to the many of the commercial products available on the market.
The firmware for the pic16F877A chip used in this design is given in the form of Basic source program that has to be compiled with PIC Simulator IDE integrated Basic compiler to get the HEX file ready to be programmed into the microcontroller.
The accu cycler project presented here is a great solution for charging and discharging NiCd and NiMH accumulators for R/C modelers and others who make use of these accumulator types.
The firmware for the 16F876A chip used in this design is given in the form of Basic source program that has to be compiled with PIC Simulator IDE integrated Basic compiler to get the HEX file ready to be programmed into the microcontroller.
Source: oshonsoft.com/ NiMH NiCd Battery Charger Circuit Alternative link:
Published: 2008/03/07 Tags: battery charger circuit, microchip projects, microcontroller projects, pic16f876 projects, pic16f877 projects, picbasic pro examples
PIC16F84 Barcode Reader Circuit
Barcode also outline some ofstandard, which is the NW-7 is a standard bar code reader by the hand scan prototype system. NW-77bit—14—3—01 NW 7-7-bit code standard, and is one of the four characters are three black bars and white bars and fine performance element to 0, with a diameter elements. Character than the width between the elements and fine. —0~9-$:/,+16—A~D4 Character is available -$:/,+ 0-9 in 16 species, and the start and stop character to character to use for the D-4 A species
PICmicro Barcode Reader
