Ultrasonic Distance Measurement circuit protel98s prepared with all the resources given circuit pcb drawing has asm and hex source code. Ultrasonic detection circuit pic assembly PIC16F873 microcontroller used in the “UCM R4OK1” with ultrasonic transmitters used ultrasonic signal measurement circuit that
This application note describes the implementation of a meter away, using ultrasonic sensors of the type-R40K1 UCM. A gust of 40KHz is transmitted through an ultrasonic sensor, the reflected ultrasonic sensor is greeted by another receiver.The calculation of the distance is done with a PIC16F873. The range of distance is measured 25cm to 300cm.
Caracteric |
MDU MDU |
Type Sensor |
Ultras or reflection |
Frequency |
40KHz |
Distance MMA |
25cm |
Distance ma |
300cm |
Resolution : P> |
1 cm |
Sensitivity |
< 1m It detects an object of faith di 8cm <1m |
Tensi and entry |
9V 9V |
Power Consumption |
60mA tip. |
source agspecinfo.com
Ultrasonic Distance Meter Circuit with PIC16F873 pic assembly source code Ultrasonic Distance Meter schematic pcb alternative link:
Published: 2008/04/04 Tags: microchip projects, microcontroller projects, pic assembly example
PC Controlled Stepper Motor Driver Circuit L298 74LS04
Although it seems simple circuits project sophisticated control of the parallel port is provided with opto 4n26 74LS04 circuits based on the isolated and amplified with IRF1010 MOSFET. L298 motor driver IC (Dual full-bridge driver) do not need to be used to strengthen the circuit datasheet you will see when you examine the file
Computer before making the connection, make sure the connection is good.
L298 Stepper Motor Driver Circuit test
