LCD Display PIC16F84A Temperature Fan Control Circuit
| November 23, 2023 Updated
Previously shared “PIC16F84 and DS1621 temperature measurement and temperature control relay” circuit’ve implemented the project is working smoothly.
Proteus isis simulation study ds1621.dll file in the file C: \ program files \ Labcenter Electronics \ Proteus 7 Professional \ models with the same file inside the folder you need to change
PIC16F84A LCD display temperature control test
Temperature Fan Control Circuit PIC16F84A picbasic pro code and circuit files:
Published: 2010/05/07 Tags: , , ,
1 Comment “LCD Display PIC16F84A Temperature Fan Control Circuit
    Simple Remote Control Tester
    The following schema is a remote control for my circuit tester. The circuit is functioning with all kinds of IR remote controls. In one recurring eye catching, a buzzer, TK19 Receiver one led and one 1 Kohm resistance.
    The circuit works with 5V. Any remote control IR Led (infrared led), and placed in control of the circuit, if any key is pressed, TK19 receiver remote control if the circuit is completed, the buzzer beeps and led flashes intermittently.
