Simple Electronic Piano with PIC16F84A
| July 16, 2023 Updated
The PIC has a white arrow in the transistor and the clock is a little to the right.
Pull-down resistor Tact switches are in line with the lower back. PIC fast 200ns port in the meantime and have pressed any button to check each one to switch ON, OFF is a pseudo-noise in the oscillator.
The PIC is more convenient and I was able to adjust the volume to a variable resistor connected to the base of the transistor because it connects directly drive the output speaker.
PIC16F84A Electronic Piano
pic16f84a-electric-piano
Every else in this program if I have to do if there’s, just so long as the program is not part else it is omitted.
If not using a subroutine, which initializes the port (0x00) and to do what we do not get anything, so just waiting to be written.
ON and OFF time to hear the sound of the generator, so I would not have exactly the scale and frequency of thought here.
Simple Electronic Piano with PIC16F84A source code and hex:
Published: 2009/01/23 Tags: , , ,
1 Comment “Simple Electronic Piano with PIC16F84A
    PIC Disassembler Program
    That run on the Windows XP operating system rare pic disassembler program
    Disassembler Program Supported PIC micro
    • pic12c508
    • pic12c509
    • pic16c52
    • pic16c54
    • pic16c55
    • pic16c56
    • pic16c57
    • pic16c58
    • pic16c84
    • pic16f83
    • pic16f84
    • pic17c42
    • pic17c43
    • pic17c44
    Which will be simple to use hacked. Hex code you can choose from the list by pressing the S button in the menu and press OK button you push controller model. Asm exit looks on the screen
