PIC16F84 king rider circuit
| July 12, 2023 Updated
In the early 1980s, the Led panel of the car named “Kit” in the K”nightRider” series became very famous, and many similar circuits were used in cars. A more advanced version of it was used in this project. A total of 32 LEDs are controlled based on the black lightning led effect circuit pic16f84 microcontroller and lm358 opamp. . The burning speed and brightness of the LEDs can be adjusted with 50k trimpots. With the “Pattern select” button, 12 different operating modes can be switched.
32-LED Knightrider with PIC Control A PIC processor simplifies the circuitry and gives 12 different lighting patterns for 32 LEDs. You can use it as a rear window brake light as an eye-catching display.
In the early 1980s there was a TV series called KnightRider. His “Star” was a highly intelligent car that went by the catchy name “Kit”. Mind you, Kit was no ordinary car. He had powers and abilities far beyond mortal chariots. Kit could talk, drive himself, and supposedly see using a series of lights in the front that were ‘scanned’ from side to side to simulate watching ahead.
Although the Knight Rider TV series ended a long time ago, such scan lights continued to gain traction, and we released two KnightRider light displays, one in November 1988 and the other in May 1996. Both of these used 16 LEDs and had a single fixed scanning screen. model.
But both of these were in the days before microcontrollers – or at least before microcontrollers were widely used in projects.
The latest version of Knight Rider has twice as many LEDs (32) and a number of different display models are available, selected using a button switch. There are four scan sequences, a chaser and a flash.
If you have the display mounted on your car’s storage rack, you can also use it as a brake light.
Knight Rider Circuit Features
32 LEDs
12 LED display models including shuffles
Adjustable speed
Adjustable LED brightness
Working with 12V
Led driver transistors BC328. The supply voltage of the black lightning circuit is 12 volts dc. Opamp and 16f84 microcontroller supply is provided with a 7805 (5 volt) regulator IC.
knight_rider_led_efekt
Source: http://www.siliconchip.com.au/cms/A_30589/article.html
PIC16F84 king rider circuit schematic pcb source code alternative link:
Published: 2008/09/05 Tags: , , , ,
1 Comment “PIC16F84 king rider circuit
    12V 50W Peltier Refrigerator
    mini fridge 1 x 50 watt peltier two stage thermal switch and a 10 amp fuse for safety in a different application with the CPU heatsink and fan
