Programmable Combination Lock Circuit PIC16F84
| August 30, 2023 Updated
Prepared by: F. San – 1 relay control circuit pic-16f84 is based on the keypad’s LED indicators and buzzer alert source. Bass. Hex code and simulation files have isis proteus. Thanks to the people who contributed to prepare.
4 × 3 matrix form lock password is entered via a keypad connected. As soon as the circuit programmable lock password is 1234. Activate the relay output that is keyed to unlock and then # 1234 is printed. If the password error relay is energized. To change the current password, for example, in 1961: 1234 * 1961 # 1961 # to be monitored as a key sequence. Changing the password fails, the old password will remain valid.
PIC16F84 Combination Lock Circuit Schematic
programlanabilir-kilit-led-buzer-isis
Combination Lock code and circuit files:
Published: 2010/02/16 Tags: , ,
1 Comment “Programmable Combination Lock Circuit PIC16F84
    PIC16C622 Microcontroller Measuring the Resistance Capacitor RC Meter Circuit
    Based on PIC16C622 microcontroller circuit between 1Ω 999Ω resistance measurement between 1nF to 999 nF capacitor measurement yapılabiliry computer’s connection to the controller software pc software with assembly prepared with Visual Basic. PIC16C622 and application circuit microchip application notes all the details about the original formula is given.
    Resistance, Capacitor Meter Circuit
