Effects of the eighth circuit’s output to 16 different effects, animation can be run with a lamp or LED advertising signs, etc., or different indicators. can be used for such applications.
100w 220v lamp driver circuit designed to drive the control circuit isolated from the optoisolator MOC3020 and triac BT137 plowed
12v led working groups connected with changing the driver circuit. Effects vary according to location SW1 … SW4 swic bottom. Also on pins RA4 pic `s connected to the oscillator circuit NE555` s Frequency according to the effects of changing.
Prepared by the circuit assembly source software. Asm, hex codes and PCBs have drawings.
Lamp Light Effects Circuit (16-Effect)
This is controlled with PIC16F84 Sequencer. If you want to know the details of programming the micro enters section microcontrollers and points to the tutorial MPLAB either login here, of course there also is include 16 effects sequencer so you can see and are something.
Source: perso.wanadoo.es/luis_ju/proyect/cqpic.html Lamp Light Effects Circuit files Alternative link:
Published: 2010/04/27 Tags: microchip projects, microcontroller projects, pic16f84 projects
Multi-Programmer Circuit PIC AVR EEPROM
Multi programmer circuit Atmel AVR, PIC16 series, and you can program the eeprom of computer software used ICprog. Circuit communication with the computer via serial RS232 port is doing.
15v dc adapter for power supply and resources available image format drawings eagle pcb’s scheme
AT89S8252 microcontroller which tested the PIC12C508, PIC12C509, PIC16F877A, PIC18F452 93Cxx 24Cxx series EEPROM can be programmed in the various integrated with additional links.
