12 channel RF relay control circuit, the receiver and transmitter circuits built on 80 pic16f628a microcontroller.100 meters can be seamlessly used said outdoor area also more important aerial circuit, I don’t know, but the market used the RF module and RF RR10 control belongs MPLAB node 8.88, is written with hi-tech PICC 9.83 (coder) and receiver (decoder) source codes and have been prepared with the Eagle pcb schema drawings at 6: 30. ULN2003AN integrated circuit is connected to the Receiver via this pic16f628a outputs 24 volt relays drivers 12v relay will be used should be selected accordingly to the used transformer power supply
source: bezkz.su/ code and eagle files for alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22275.zip
Published: 2013/11/08 Tags: microchip projects, microcontroller projects, pic16f628 projects
LM3914 120 Led Stereo Vu meter circuit
VU meter circuit left and right channel as the second section consists of circuits 6 10 s LED display used ultimately each display 10 LEDs where the per channel 60 LEDs are used a total of 120 LEDs at the same time per channel 6 LM3914 is used to integrate a one synchronous with the works, but located on the first audio signal entering the circuit 1k (application used 3.3K) by measuring with a multimeter necessary to adjust potentiometers
RF Relaissteuerung mit PIC16F628
12-Kanal-RF-relais-Steuerung-Schaltung, die in Sender und Empfänger-schaltungen gebaut, auf 80 pic16f628a mikrocontroller.100 Meter, kann nahtlos verwendet werden, sagte der outdoor-Bereich auch wichtiger Antenne Stromkreis, ich weiß es nicht, aber der Markt an gebrauchten HF-Modul und RF-RR10-Steuerelement gehört MPLAB Knoten 8.88, geschrieben mit hi-tech PICC 9.83 (coder) und Empfänger (decoder), Quellcodes und vorbereitet wurden, mit der Eagle pcb-schema-Zeichnungen auf 6: 30. ULN2003AN integrierten Schaltung verbunden ist, um den Empfänger über diese pic16f628a-Ausgänge 24 volt relais-Treiber 12v-relais verwendet werden, sollten entsprechend ausgewählt werden, um den Übertrager-Netzteil
