PIC16C620 DC to DC Converter Circuit SMPS
| Updated on August 30, 2023
Dc to dc converter circuit based on the powerful but pleasing formulas given all the details about the project is the original microchip application notes. pic16c620 Source code flow diagramm AMS assembly area and it’s a lot more information
DC DC Converter Circuitt Using a PICmicro® Microcontroller
DCDC-CONVERTER-SYSTEM-SMPS
In many applications, a DC/DC Converter is used to produce a regulated voltage or current, derived from an unregulated power supply, or from a battery. Examples of these applications include battery chargers, electronic air purifiers, emergency exit signs, and distributed power systems.
In some of those applications, a dedicated Switched Mode Power Supply (SMPS) Controller IC is used in conjunction with a microcontroller. In other applications, however, a dedicated SMPS Controller IC may be overkill. An alternative approach is to generate a low cost SMPS function in a smart microcontroller, such as the PIC16C620A. This Application Note shows a method of using the microcontroller to perform simple SMPS control functions.
DC / DC INVERTER
There are several popular DC/DC Converter topologies, such as Boost and Fly-back Converter topologies. The DC/DC Converter used in this example is a Buck (or step-down) Converter topology, also popular, is the Buck Converter, consisting of: transistor Q1, diode D1, inductor L1 and capacitor C1.
Transistor Q2 is used as a level translator. PICmicro device PORTB output to turn Q1 on or off. Application Note AN701 describes how to make a Buck Converter. Works. It also provides a general guide on
voltage-source-dc-dc-converter-using-pic16c620a
PICmicro DC to DC Converter Circuit files:
Publication date: 2010/02/07 Tags: , ,
1 Comment “PIC16C620 DC to DC Converter Circuit SMPS
