PIC12F629 PWM SMPS Control
| July 5, 2023 Updated
PIC12F629 microcontroller is done with PWM Control GP0, GP1 output MOSFETs with BUK555 in the SMPS transformer EI33 if sülü. 25kHz operating frequency of the circuit tests made ​​with 50w load. ATX SMPS power supply transformer ei33 from the author of deploying and re-festooned dressing.
It is a chopper to 25 kHz built around a PIC12F629 to operate on a 12V battery.It uses a transformer recovered in a power PC.The holding power has been tested up to 50 W, the secondary is wound depending on the need
pic12f629-transformer-recovered-pc-power-supply-ei33-pwm-microcontroller
ei33-Winding-transformer-atx-ei33
Source: pagesperso-orange.fr PIC12F629 PWM SMPS Control alternative link:
Published: 2008/03/06 Tags: , , , , ,
2 Comments “PIC12F629 PWM SMPS Control
    1.5V to 5V DC DC Converter 3V to 9V DC DC Converter Circuits LT1073
    Two DC DC Converters project than 1.5 volts and 3 volts, 5 volts from the 9 volt converter converter LT1073 DC to DC converter integrated circuit used in two
    The LT1073 is a voltage converter DC-DC. This circuit requires only five external components in its adjustable (three components in its 5V – LT1073-5).The input voltage, which can go down to 1V allows circuit uses them for applications powered by a single stack of 1.5 V. Le courant de repos n’excède pas 135µA. The quiescent current does not exceed 135 µ A. Pour une tension de sortie de 5V le circuit For an output voltage of 5V circuit can supply a current of 40mA with an input voltage of 1.25 V and a current of 10mA for an input voltage of 1V.
    Der Mikrocontroller PIC12F629 wird mit der PWM-Steuerung GP0 und den Ausgangs-MOSFETs GP1 mit BUK555 im SMPS-Transformator EI33 ausgeführt, falls dies erforderlich ist. 25kHz Betriebsfrequenz der Schaltungstests mit 50w Last. ATX SMPS-Netzteiltransformator ei33 vom Verfasser des Bereitstellens und erneuten Festonierens des Verbands.
    Es ist ein Chopper auf 25 kHz, der um einen PIC12F629 gebaut ist und mit einer 12-V-Batterie betrieben werden kann. Er verwendet einen Transformator, der in einem Leistungs-PC wiederhergestellt wurde. Die Halteleistung wurde auf 50 W getestet
