PIC Microcontroller-Controlled Electronic Piano Project
| July 31, 2024 Updated
Handmade in electronic piano project PIC16F690, PIC16F887 or PIC16F886. PIC microcontrollers can be used to connect to the legs of metal coins used as key microcontroller with ADC circuit 36 is used for touch-key hues quite well
C source code of all the resources given to the Electronic Piano project on the site of the circuit logic and circuit realization detailed information about the operation of the software given.
Electronic Piano Circuit finished version
mikro-denetleyici-piyano-muzik-diy-piano
If a site other electronic piano circuit applied in wooden boxes (Proteus ares have PCBs) in PIC16F690 PIC outputs used and reinforced with an integrated stereo amplifier TDA2822
Sample hand-made electronic piano music;
el-yapimi-elektronik-piyano
Site 1: Link Site 2: Link Electronic Piano Circuit code files alternative link :
Published: 2010/10/17 Tags: ,
1 Comment “PIC Microcontroller-Controlled Electronic Piano Project
    MSP430 examples
    Texas Instruments MSP430 MCU series microcontrollers `s prepared for hundreds of applications with C language prepared sample codes (IAR Embedded Workbench Version 3.41 A) in the comment section of code specified in their use.
