Experiment with a lot of features for free pic development board PCB diagram drawing and painting has been completed state.
40 PIC series can be used for serial port interface (MAX232) button link 2 × 16 LCD unit, LEDs, 7-segment display indicators DS18S20, 24C256, 25C040, 93C86 EEPROM section and PCF8583 plus any external input logout has links in pdf format pcb drawing acrobat reader with the program You can print directly from open to adjust
Development Board for 40-pin PIC-Microcontrollers
The development board project presented here is a fully documented project that can be used for testing many of the typical applications and peripheral connections where PIC microcontrollers are used. It can be used with all 40 pin microcontrollers supported by PIC and PIC18 Simulator IDE applications.
Experiment Board for 40pin PICMicro
source oshonsoft.com Experiment Board for 40-pin PIC-Microcontrollers Development pcb schematic alternative link:
Published: 2008/03/07 Tags: pic development board
NiMH NiCd Battery Charger Circuit PIC16F877 PIC16F876
NiCd NiMH Charger Circuit The accu cycler project presented here is an excellent solution for charging and discharging NiCd and NiMH accumulators for R/C modelers and others who make use of these accumulator types. With its performance it is very close to the many of the commercial products available on the market.
The firmware for the pic16F877A chip used in this design is given in the form of Basic source program that has to be compiled with PIC Simulator IDE integrated Basic compiler to get the HEX file ready to be programmed into the microcontroller.
