UltraCAD company deploys with this program as a free PCB in the heat of the current-carrying capacity and Alex DLE 70 Professional displays the values. Calculation program does not require installation to work, the file must be in the windows system folder installed vbrun300
A motor drive circuit of shunt resistance on the pcb according to the schedule made by drawing a circle road:)
# Track width; “Mil” means “thou” or thousandths of an inch.
# Copper thickness; most high quality double-sided PCB copper is 2 oz type.
# Copper thickness; hobby grade single sided is often 1 oz type.To calculate a PCB track resistor;
# Enter Width = 10 (standard PCB fine track)
# Enter Thickness = 2 (standard PCB copper)
# Enter Length = 1 inch
# Click “recalc” (answer is in ohms per inch of track)Then check the track does not get too hot;
# Enter your max Amps
# Click Temp CHANGE (Solve)
# Observe temp, check resistance has not risen too much
# Try to keep track temp change less than 10’C
Source: http://www.romanblack.com/pcbtemp.htm Alternative link:
Published: 2011/03/15 Tags: electronics software tools
Security Alarm Circuit with PIC16F877 LCD
Security Alarm project 16f877 microcontroller Board 2×16 lcd indicator alarm circuit connected to the keypad on the necessary adjustments can be made. Circuit diagram pcb drawings, asm source, hex codes, alarm installation, lcd menu information (in English). Alarm circuit 8 pieces TRIAC output connect this outputs relay can be controlled by a variety of devices such as elements.
