Indicator section in Thermo Meter circuit 7 Segment display driver based on ICL7107, temperature sensors used, LM35 Fan speed controls, standard circuit in the datasheet file made with 3 pieces of LM317 is not a special circuit that can be used. CD-ROM for boxing in the circuit Provides great convenience for mounting in a used computer case.
PC Fan Panel Speed Control
In its introduction, a brief description of the panel. Its main part is a kit AVT 2389 – Four thermometer sensing LM 35, their accuracy in my case is ok 1C (or rather Difference between the sensors – in pairs at intervals of time and come from different series). Complement the thermometer is “fanbus” (regulator) based on a well-known to all LM317T, enables a regulation in the range of 6V ok to 10.5 V
Source: forum.purepc.pl PC Fan Speed Control schematic pcb alternative link:
Published: 2008/11/08 Tags: analog circuits projects
Microchip C Sample Code Hi Tech C Example Archive
Sample projects for the Microchip PIC micro series of microcontrollers, including the PIC12x, PIC16x, PIC18x, PIC24x, and dsPICx microcontrollers.
Hi Tech C Example Application
