TDA1518BQ TDA1516BQ Car amplifier circuit
| Updated on June 22, 2014
TDA1516BQ printed circuit board and integrated amplifier compatible with TDA1518BQ single source supply voltage of 6 volts DC …. 18volt dc circuit 2 pieces made ​​especially auto tape is used in printed circuit board PCB size can be used as stereo 2x24w small cpu cooler and fan for cooling is sufficient.
Car power amplifier TDA1516BQ TDA1518BQ 24W BTL or 2 x12w
The TDA1518BQ TDA1516BQ is an integrated class-B output amplifier Fixed gain Good ripple rejection Mute/stand-by switch Load dump protection…
tda1516bq-tda1518bq
tda1516bq-tda1518bq-circuit-schema
tda1516bq-tda1518bq-pcb
Source: masterkit.ru
Publication date: 2012/08/20 Tags: ,
1 Comment “TDA1518BQ TDA1516BQ Car amplifier circuit
    PCB with Aluminum Foil Printing
    Ironing Board with pcb or laminator while pressing a lot of paper to be used with pcb type there Avinash, label, handmade paper, etc. I’m experimenting with the latest label paper, and I have no need to use other paper continue but continues to have different methods.
    The author used the aluminum foil for the pressure of the pcb before tinfoil on the edges of the foil blanks in A4 paper taking meandering steadies
