Stereo tone control circuit bass, treble, balance and volume controls OPA2107 op amp is not used in the original series pretty open is frequently used in high-quality professional audio applications not found in the market place TL072, NE5532 opamps used. HiFi tone control circuit’s PCB drawing and layout diagram does not have a circuit is not complicated, but actually supply circuit has a bit muddled mess
Circuit power supply 2x15v symmetric 7815 and 7915 regulator IC used in the power supply 2 toroidal transformer is used regulator solid same 2 made OPAMPs separate fed essentially a single transformer enough so that we know the classic symmetrical supply circuit is adequate but that’s hi fi, quality and so on. 🙂 When we go into detail sounds a bit complicated and costly electronics …
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19692.zip
Published: 2012/09/08 Tags: audio control circuits
Lego Kit With Automatic Book Scanner Robot
It can scan the books to the computer to transfer the most puzzling part to turn the pages in a professional for this job is a lot of work also have devices generating writes auto DIY book scanner with mechanical portions of the Lego robot kit is already the most puzzling according to the speed of the motor control circuitry to make the browser after mechanical stays
Automatic book scanner have motor control Robot in the source drawings prepared with LeoCad Motor Driver Circuits, you can choose an appropriate category, and Cnc control circuit
How to Make a Full Auto Book Scanner Once started, the machine opens the each page of the book and scans the content. The whole process is automatic. The lesson of this story is that LEGO is grea
Operationsverstärker Stereo-Hi-Fi-Klangregelkreis
Stereo-Klangregelung Bass-, Höhen-, Balance- und Lautstärkeregler OPA2107 Operationsverstärker wird nicht in der Original-Serie verwendet ziemlich offen ist häufig in hochwertigen professionellen Audio-Anwendungen nicht auf dem Markt TL072, NE5532 OPAMPs verwendet verwendet. HiFi-Ton Steuerschaltung PCB Zeichnung und Layout-Diagramm hat keine Schaltung ist nicht kompliziert, aber tatsächlich Versorgungsschaltung hat ein bisschen verwirrte Unordnung
Schaltnetzteil 2x15v symmetrische 7815 und 7915 Regler IC in der Stromversorgung verwendet 2 Ringkerntransformator wird Regler verwendet soliden gleichen 2 Operationsverstärker getrennt im Wesentlichen einen einzigen Transformator genug gespeist, so dass wir wissen, die klassische symmetrische Versorgungsschaltung ist ausreichend, aber das ist hallo Fi , Qualität und so weiter. 🙂 Wenn wir ins Detail gehen, klingt ein bisschen kompliziert und teuer Elektronik …
