5V to 200V with NE555 DC DC Converter
| September 14, 2023 Updated
The astable multivibrator using NE555 integrated timing voltage of 5 volts DC to 200 volts to 200 volts dc voltage can upgrade to the power 20 of which can be taken out
“In addition to @timpat” Adapted from my teacher useful information: transistors used in the original scheme can give bc337’n the current (at 5V) to a maximum of 800. In this case, even if we accept that it is 100% of the yield on the secondary side of the transformer 200V’t the maximum current that can be drawn: Isxvs = ıpxvp => Business = (ıpxvp) / Vs = (0.8 × 5) / 200 = 20mA will be.
5V to 200V Circuit
5v-200v-dcdc-donusturucu
CAUTION circuit at the output of the high voltage (200 volts DC) consists Be careful Pay attention to the capacitor connection + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
Source pagesperso-orange.fr 555 5V to 200V Circuit files alternative link:
Published: 2010/02/22 Tags: , ,
1 Comment “5V to 200V with NE555 DC DC Converter
    MicroC LED Blink Example PIC12F675 Police Lamp Strobe Flashing Circuit
    In this article microcar hello friends with you in a simple way with the police emergency lights in the form of a burning light I offer project. Microcar, which features extensive use of a compiler. Entirely in C language-based structure. Anyone who knows C can be easily adapted. With little change in the program, such as Hi-tech c compiler can be used in protonc Picbasic.
    12F675 can be found very easily in the market and how we can do this work I present to you in an understandable manner. (For anyone who knows the basics of the C language is very easy to understand.)
