MSP430F149 Breakout Board Protel PCB
| Updated on August 5, 2024
MSP430 UltraLow Power 16bit MCU MSP430f149 prepared with a simple experiment that you can use in your projects to work on board MSP430f149 basic materials for PCBs and for the socket’s input and output ports. Protel is prepared by a printed circuit board.
MSP430F149 Breakout Board PCB
msp430f149-pcb
MSP430F149 Breakout Board Protel PCB files download:
ลžifre-Pass: 320volt.com
Publication date: 2010/11/17 Tags: ,
1 Comment “MSP430F149 Breakout Board Protel PCB
    Hand-Made Energy-Efficient 220V LED Lamp Lighting Circiut Transformerless
    Eventually I led lamp did ๐Ÿ™‚ very common fault that apartment lamp caused it in our region voltage 230v vicinity at night 240v is getting occasional spikes to come in the not to mention electronic circuit controlled economic CFL lamps is not based quality though often fail because they led lamp wanted to try.
    I use LEDs in the base class from 5 `c ๐Ÿ™‚ still a good performance at least provided adequate lighting for apartments
    The main circuit 38 led FS-801 models sold in china I’ve changed a few supplies to use 50 LEDs
