Carbon monoxide alarm circuit, which detects using the MQ-7-CO Sensor, operates on the PIC16F88 Microcontroller, the operating voltage is 12v dc, it detects carbon monoxide and pulls the 12v relay in the circuit according to the level, whatever is connected to the relay (siren, lamp, etc.) is working.
Carbon Monoxide Alert Carbon monoxide is an insidious poison that kills and kills. Colorless, odorless and sneaking up on you! By the time the first victims become aware of carbon monoxide poisoning, it may be too late.
Carbon monoxide (CO) is a fairly simple gas consisting of one carbon and one oxygen atom. It will eventually mate with a spare oxygen atom and reform as the more natural – and relatively harmless – carbon dioxide or CO2. But it remained CO long enough to do real harm to us as mortals! What’s more, carbon monoxide poisoning can be very difficult to treat.
While carbon dioxide (CO2) isn’t as toxic (in fact, the air we breathe naturally contains 0.03% carbon dioxide), it can replace enough oxygen in the air and therefore cause suffocation.
However, significant amounts of carbon monoxide (CO) are toxic because it affects the transport of oxygen in our blood. One of the main problems is that CO has 200 times greater affinity for hemoglobin in your blood.
It literally prevents the blood supply from carrying oxygen around the body and most importantly in the brain. When the brain suffers from oxygen starvation, permanent damage and even death can result in a surprisingly short time – just a few minutes.
The CO sensor goes through a 150 second cycle, clears itself for one minute, and looks for carbon monoxide for the next 90 seconds. When CO is detected, the output resistance drops significantly.
PIC16F88 Carbon Monoxide MQ-7 Alarm Circuit
Source: http://www.siliconchip.com.au/cms/A_105031/article.html
Carbon Monoxide Alarm schematic pcb PIC16F88 pic assembly source code alternative link:
Published: 2008/09/02 Tags: microchip projects, microcontroller projects, pic assembly example, pic16f88 projects
PIC16F628 Microcontroller Heart Beat Control Circuit
I understand the circuit with first aid training for use in the designed a kind of electronic heart in training model made with heart massage in the control may be used for a different circuit, especially medical much about the circuit being a source Considering that the isis a simulation with prepare and try them there
