“Polycontrolled Interactive LED Mood Light” is based on Atmel ATMEGA168/88 quite a strange RGB LED application design professional as well as various modes, speed, the program’s options.
I hope I know the main parts used in the market are located
LMC6482 (National Semiconductors, DIP8), LIS2L02AS4-TR (ST, SOIC 24), MAX712CP A + (Maxim / Dallas, DIP 16), ATMEGA168/88 (Atmel, DIP 28), MAX603CS A + (Maxim / Dallas, SOIC 8), HMC6352
Description
This device is capable of his two flares in different colors of the rainbow (color circle) to shine. It has three modes, a compass mode (mode 1), in which the two flares show the direction in which the device with its axis shows, a move mode (mode 2), in which the two flares its color depending on the situation of the unit in the X-and Y-direction change, and a program mode (mode 3), in which the two flares independently one from 8 colour change programmes can play. This device has a built-in rechargeable battery and can Volladung about 2 hours regardless of the network in operation.
source synvox.com ATMEGA168 Mood Poly Controlled Interactive LED Light alternative link:
Published: 2008/02/18 Tags: avr project, microcontroller projects
Microphone Preamp Equalizer Circuit Channelstrip
Channel strip microphone preamp and equalizer features a volume control circuit with project drawings are quite detailed diagrams and printed circuit board.
+/-15dB @ 12Khz shelving (switchable, either 8Khz or 16Khz)
+/-15dB from 600hZ to 10Khz peaking/dipping
+/-15dB from 150Hz to 2.4Khz peaking/dipping
+/-15dB @ 60Hz shelving (switchable, either 60Hz or 120Hz)
Highpass filter 50Hz to 800Hzr 12dB/oct.-Balanced mic preamp (impedance 2kohm)
-70dB to -30dB (with 30dB max gain range: 70dB)
Switchabel 30dB pad-Unbalanced line input -10dB to +20dB Switchable 48V phantom power-Phase switch
„Polycontrolled Interactive LED Mood Light“ basiert auf Atmel ATMEGA168 / 88, einer ziemlich seltsamen professionellen RGB-LED-Anwendungsentwicklung sowie verschiedenen Modi, Geschwindigkeit und Programmoptionen.
Ich hoffe, ich weiß, dass die wichtigsten auf dem Markt verwendeten Teile lokalisiert sind
