ATTINY13 Atmel microcontroller installed on the circuit model helicopter is checking the voltage of the battery the battery (or battery) voltage circuit when the level set LEDs, buzzer, giving the alam. ATTINY13 PB2, PB1, and PB0 pin chassis yaplılarak short circuit between the alarm can be set at a certain voltage circuit has very little material, if prepared pcb printed circuit board with SMD components becomes much smaller.
Battery alarm for model helicopters
In the model aircraft enjoy lithium polymer batteries (abbreviated Li-Po) very popular, but they, unlike their counterparts in mobile phones, cameras or portable media players, no built-in protection circuit. What this means for the user that he must be vigilant in seeing that the sensitive battery during charging and discharging is not damaged.
When you load one need most to worry, there are good chargers specifically for model or the model is the same for a suitable charger. Somewhat more problematic is the discharge – here, you naturally want to take advantage of the battery capacity as possible, on the other hand, should not the battery voltage falls below the permissible limit of 3.0 V per cell. Some models indicate these critical flight condition with an LED, but this is not always recognized in time. For this reason I developed the following circuit. This monitors the battery voltage in the flight model and shows by intense flashes of high brightness LEDs in time, the impending discharge of the battery. It can still be landed safely and the battery is protected against deep discharge.
Source: s-huehn.de/elektronik/klprojekte/akkualarm/akkualarm.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19538.zip
Published: 2012/08/20 Tags: avr project, microcontroller projects, simple circuit projects
TDA1518BQ TDA1516BQ Car amplifier circuit
TDA1516BQ printed circuit board and integrated amplifier compatible with TDA1518BQ single source supply voltage of 6 volts DC …. 18volt dc circuit 2 pieces made especially auto tape is used in printed circuit board PCB size can be used as stereo 2x24w small cpu cooler and fan for cooling is sufficient.
Car power amplifier TDA1516BQ TDA1518BQ 24W BTL or 2 x12w
The TDA1518BQ TDA1516BQ is an integrated class-B output amplifier Fixed gain Good ripple rejection Mute/stand-by switch Load dump protection…
